fileRepository.LoadText topic
hi,
After executing code:
var fileRepository = Things[fileRepository];
var fileContent = fileRepository.LoadText({ path: preparedFile });
file is "locked". I've even thought that there is something like close method (fileContent.close();) - but it's not 😞
any idea how to unlock it??
thx
raluca_edu
What version are you using?
This issue was corrected in 8.3.0.
Please find related article here.
Best regards,
Raluca Edu
raluca_edu
Best regards,
Raluca Edu
Gucio16-PearlAuthor
hi,
ThingWorx 8.1.3-b121
regards
raluca_edu
On versions before 8.3, this is reported as defect to R&D.
Unfortunately, I do not know any workaround for this issue.
If you have the possibility to upgrade/change version to 8.3 , then LoadText will not be an issue anymore.
Best regards,
Raluca Edu
