Jamal Ashraf
Oct 24, 2025 6:22 AM UTC
FileRepositoryDownloader returns 406 error when file name contains # character -even when URL encode
Hi everyone,
I’m running into an issue with ThingWorx FileRepositoryDownloader when trying to download files that contain a # character in their name.
For example, I have a file in my repository called:
test#2.pdf
When I build the URL dynamically using encodeURIComponent, it looks like this:
https://<server>/Thingworx/FileRepositoryDownloader?download-repository=test.FileRepository&directRender=true&download-path=%2F1760338581178%2F1761219448752%2Ftest%232.pdf
However, the request always fails with:
HTTP 406 – Not Acceptable
and the response shows Content-Length: 0 from the ThingWorx Nginx server.
If I rename the file (for example to test_2.pdf), the same request works perfectly.
It seems that even though the filename is correctly encoded (%23), the FileRepositoryDownloader servlet doesn’t handle # correctly inside the download-path query string.
Has anyone else encountered this before?
i am using webgl widget to render pdf in browser..
 output = "/Thingworx/FileRepositoryDownloader?download-repository=" + fileRepository + "&directRender=true&download-path=" + encodeURIComponent(path);
Is there a known workaround or a configuration change to make ThingWorx accept such filenames (without renaming them)?
Note All German characters in pdf name were causing an issue but after adding this encodeURIComponent(path) in generating pdf path all problems were resolved. special characters mean ü ö but this only file which has # hash sign is causing an issue.
Any help or confirmation would be greatly appreciated
Rocko
Oct 24, 2025 7:04 AM UTC
Two ideas:
1) You could try the alternative link to download, without the FileRepositoryDownloader.
<Thingworx>/FileRepositories/myRepository/myFile.txt
2) Check TWX and Tomcat log. There might be more information,  HTTP 406 – Not Acceptable
sounds a bit like the character was forbidden - there is a config about allowed characters, maybe you run into this.
I think it's in esapi/validation.properties
Jamal Ashraf
Oct 24, 2025 7:10 AM UTC
Thanks @Rocko  are you talking about platform-settings.json file? Or how can i find this configs where these all validation properties are mentioned?
Rocko
Oct 24, 2025 7:19 AM UTC
no, esapi is a subdirectory in your TWX ThingworxStorage directory. There might be also something in the help about this. If this is the issue, you have to add # as an allowed character into the regular expression.
