6-Contributor
Finding data in json from an infotable.
Can somebody help me to write a service in thingworx where infotable data value is checked if it is found in a json data.
Thanks.
  • Iterate the infotable
  • Compare values with JSON from infotable
  • if found, get the required values
var info = [INFOTABLE];
for( var i = 0; i < info.length; i++){
 //Get the infotable row values
 //Search in JSON
 if(isFound == true){
 //Get the required value
If possible share the sample dataset.
Can you please explain bit more about your use case?
6-Contributor
I have a json data which has multiple json arrays. I have an infotable which has data which can be compared to the json data. If at all i find the value in the json then i have to get certain key value pairs of that object.
 //Search in JSON
