Finding the number of fields in a datashape
Hi all
In relation to this article: https://community.ptc.com/t5/IoT-Tips/DataShape-Nuances-Tips-Tricks/ta-p/817583?search-action-id=107104588871&search-result-uid=817583,
How can one find the number of fields in a datashape?
I have tried this:
let result = infotableData.DataShapeName.fields.length;
However this is the error I keep getting:  TypeError: Cannot read property "fields" from undefined.
Thank you.
Arun_CAnswer
Hi @Janicen ,
Im not sure why "let result = infotableData.DataShapeName.fields.length;" is not working.
But you can try this below code to find the field count from infotable.
let dataShapeFields = infotableData.dataShape.fields;
var fieldCount = 0;
for (let fieldName in dataShapeFields) {
fieldCount++;
result = fieldCount;
Thanks & Regards,
Arun C
Arun_C16-PearlAnswer
Hi @Janicen ,
var fieldCount = 0;
fieldCount++;
Thanks & Regards,
Arun C
Hi @Janicen  & @Arun_C
You can avoid the loop by below code
let dataShapeFields = infoTable.dataShape.fields;
var result = Object.keys(dataShapeFields).length;
/VR
