First login use a specific mashup
Hi All
I am trying to find out if it is possible that when my users first login and complete the entries of specific required fields that the next time they go straight to my main page.
Anyone know how this might be done?
Darryl
Hello Darryl Sawyer,
If you are talking about auto-redirection on second login,hope below thread helps you.
Mashup flashing while redirecting
Tarun Nayyar
22-Sapphire I
November 14, 2017
Using a script, User Extension Property and some Contained Mashups, you can use that to figure out if it is the User's first time, and then swap the contained mashup to the 'initial setup' one. (You can dynamically assign a Mashup name to a contained mashup space in runtime)
Darryl1-VisitorAuthor
Hi Pai
Thanks, I get how to check the last login time to see if user has logged in before.
But I not sure how to use a contained mashup?  Could you elaborate on that for me?
Darryl
22-Sapphire I
November 16, 2017
Take a look at this post, I hope that explains some of the possible and how to do it.
Passing Values to Contained Mashups that Dynamically change
