rattmice
Nov 21, 2025 2:36 PM UTC
Flow Configuration Error
I'm having a problem getting Flow 10 to get configured with Foundation 10.  All the services start and I can connect to Foundation via the Flow nginx port but I get the following error when running WorkflowSubsystem.ValidateFlowSetup:
Found 1 issues. [FLOW-API-01] - Failed to connect to Flow: Internal Server Error For more information, refer to the 'Troubleshooting Your Installation' topic in the Help Center.
The ApplicationLog has these errors:
2025-11-21 14:29:06.092+0000 [L: ERROR] [O: c.t.s.s.f.WorkflowSubsystem] [I: ] [U: Administrator] [S: ] [P: ] [T: https-openssl-nio-8443-exec-7] Failed to get Delegated UserOAuths : Internal Server Error
2025-11-21 14:29:06.092+0000 [L: ERROR] [O: c.t.f.f.FlowDelegatedOAuthFilter] [I: ] [U: Administrator] [S: ] [P: ] [T: https-openssl-nio-8443-exec-7] Unable to initialize session attributes
 I don't have SSO currently enabled although I did have it on in previous attempts so I'm not sure with there is an OAuth error.
rattmice
rattmiceAnswer
Dec 1, 2025 1:19 PM UTC
Thanks but ErrorLog didn't really contain anything valuable.  The Flow exchange error had this:
{"module":"flow-exchange","timestamp":"2025-11-25T01:10:37.462Z","level":"error","message":"unauthorized access”}
And the Flow oauth log had this:
{"module":"flow-oauth","timestamp":"2025-11-25T01:09:33.307Z","level":"info","message":"inbound : Connection Failed: {"code":"ECONNREFUSED"}"}
 None of the logs were very direct in indicating exactly what was wrong and the connection failed was difficult to track down because I could access everything via browser/curl.
In the end, it turned out that I messed up the orchestration.crt by following the instructions to generate those by hand instead of copying what was already there for Foundation.
18-Opal
Nov 27, 2025 6:15 PM UTC
Just a generic advice, sorry -- try to check other log files, e.g. ErrorLog.log. They might contain more details about this issue, some stack traces and context information.
rattmice
rattmice14-AlexandriteAuthorAnswer
