Font Labeling - Upload custom fonts
I am using Font labeling Widget but i can't able to upload ttf fonts using Media entity. Is there any solution?
Thingworx Version 8.0
Sathishkumar C.
posipovaAnswer
20-Turquoise
Please note that the extension provided in the Marketplace is in "as-is" condition and is not currently supported
This item has been tested and certified by ThingWorx to successfully work with the ThingWorx platform, however this item is not currently supported by ThingWorx. By utilizing this item you acknowledge that the content is provided in ‘as-is’ condition and support will not be provided
posipova20-TurquoiseAnswer
20-Turquoise
I am having this same issue in ThingWorx 8.  I got the Font Label extension installed, but when I attempt to import a .ttf file into the media entity, I get an error thrown on the application log:  Internal error: java.lang.IllegalArgumentException: image == null!
I understand that the widget is not supported any more but I now have to completely recreate large chunks of mashups that used this widget in 7.3.  Are there any workarounds or fixes that anybody has run into?
Thanks.
20-Turquoise
Bob Neubaum​ anything you guys could assist with?
