form login not working
I have created an Organization, and tried to logging in but it giving me this error, though I'm a part of admin group with all access and even I have provided all the correct credentials.
It is giving 405 http error.
Hi @RC_10864577  Try to login in incognito mode and share the application logs if issue will resolved.
  • Form Login only works as expected when ThingWorx Authentication is enabled
@RC_10864577 Are you part of the Organization as well? You need to be,
yes I'm part of org
