Format datetime for expression widget
Hi all,
I need to format current date time on ThingWorx expression widget, but javascript functions do not work without libraries (i.e. dateFormat(newDate(), "dd-MM-YYYY HH:mm")). How can I format datetime with native functions?
Elisabetta
You can use Javascript Standard DateTime Format functions, something like:
new Date().toLocaleString()
18-Opal
To expand on Carles' reply:
  1. There's another ugly way of formatting it via date.getFullYear() + "-" + ....
  2. There are ThingWorx widgets which support date formatting on the client side (e.g. Value Display, Grid, ...)
  3. You can pre-format on the server side and return in a temporary INFOTABLE field, e.g. "displayDate"
Carles' suggestion + Option (2) are the best variants, because they take into account user's locale settings.
Constantine
Yup, but I would never use Option 3, as it will be formated at Server TimeZone not at user's Timezone 😉
18-Opal
Agree, (3) is a bad idea, it would be the last thing I recommend.
Having said that, there are some exceptions:
  1. They define timezone per user explicitly and get into trouble of using it correctly on the server side (often needed when the app sends something outside -- emails, SMS, etc.)
  2. All users are (and will be) in the same timezone and the server can be configured accordingly
As a rule of thumb formatting date/time on the server side is almost always a bad idea. But if (and only if) you have a very clear idea about how it works (like your famous extension), then you can break the rules sometimes 🙂
