Sep 23, 2019 9:25 PM UTC
Foundation - 503 Service Unavailable error
Hi ,
I am also facing same error message while trying to access the ThingWorx composer. Hence attaching the log files.
1. Setttings.json file is at ThingworxPlatform folder
2. JDBC .Jar files are at <Tomcat>\lib folder
3. Table are created in thingworx database
4. Using Thingworx 8.4.4 with MS SQL server database
gone through article Connections could not be acquired from the underlying database
Please give your opinions
Json file is as :
"PlatformSettingsConfig": {
"AdministratorUserSettings": {
"InitialPassword": "trUf6yuz2?_Gub"
"OrchestrationSettings": {
"EnableOrchestration": true,
"QueueHost": "win-5aoe9h447vu",
"QueuePort": 5672,
"QueueName": "256mb",
"QueueUsername": "flowuser",
"QueuePassword": "e24bbe712caab365b11a5a4f4b21a0b3",
"QueueVHost": "orchestration"
"PersistenceProviderPackageConfigs": {
"MssqlPersistenceProviderPackage": {
"ConnectionInformation": {
"driverClass": "com.microsoft.sqlserver.jdbc.SQLServerDriver",
"jdbcUrl": "jdbc:sqlserver://localhost:1433;databaseName=thingworx;applicationName=Thingworx;",
"password": "PlantPAxPTC@1234",
"username": "twadmin"
slangleyAnswer
Support
Oct 3, 2019 6:22 PM UTC
Hi @GSPatil.
Are you having issues importing just this one extension or all extensions?  If this is affecting all extensions you probably need to check \ThingworxPlatform\platform-settings.com to ensure the Extension Package Import policy exists?  Here's an example:
                "password": "twadmin",
        "LicensingConnectionSettings":{
            "username":"username",
            "password":"password"
        "ExtensionPackageImportPolicy": {
            "allowCSSResources": true,
            "allowEntities": true,
            "allowExtensibleEntities": true,
            "allowJSONResources": true,
            "allowJarResources": true,
            "allowJavascriptResources": true,
            "allowWebAppResources": true,
            "importEnabled": true
        "ContentTypeSettings": {
            "supportedMediaEntityContentTypes": [
                "image/svg+xml",
                "image/png",
                "image/gif",
                "image/bmp",
                "image/jpeg",
                "application/pdf",
                "image/vnd.microsoft.icon"
I don't have any knowledge indicating that the relational database extension is no longer needed but I will check on it..
--Sharon
raluca_edu
Sep 24, 2019 12:59 PM UTC
Can you connect in MSSQL with twadmin user? If yes, I am recommending to check Tomcat logs, there some exceptions are thrown and can help with investigation.
If you want, you can attach Tomcat logs here to look into.
Thank you,
Raluca Edu
GSPatil1-VisitorAuthor
Sep 24, 2019 2:49 PM UTC
Thanks for immediate reply, Yes I am able to connect MSSQL  to 'twadmin' user.
Also I have gone through the logs, but could not find any error.  Attaching available logs for your review.
Regards;
Ganesh Shete
raluca_edu
Sep 24, 2019 3:03 PM UTC
I think I found why this is failing:
ERROR com.thingworx.system.configuration.PlatformSettings - Configuration setting ContentTypeSettings.supportedMediaEntityContentTypes cannot be null
You need to add ContentTypeSettings in platform-settings.json , please follow this article: https://www.ptc.com/en/support/article?n=CS305798
After this, restart Tomcat.
Best regards,
Raluca Edu
