7-Bedrock
FROM XML snippet reg...
I have got a xml file using "GetXML''. I want to convert it to an infotable, so am using the "FromXML" snippet.But when i execute it , it says "Must have a datashape defined to add rows." How to rectify this?
Also , in GetXML, is it possible to add xml file from local storage instead of adding it from an url?
Sadagopan Ponmani
raluca_edu
Please follow this article: https://www.ptc.com/en/support/article?n=CS218242
You need to use a datashape for FromXML service.
Regarding the GetXML question, there is no parameter defined to get XML from a storage.
Hope it helps,
Raluca Edu
raluca_edu
Hope it helps,
Raluca Edu
