Funny Bug? within MSSQL Select
Hey guys,
can someone explain me that "bug?" which is growing from 8.2 --> current version.
SELECT MAX(VALUE_TIME)
FROM MyEpicTableDataAnonym
result = 2019-10.12 .....
and
SELECT MAX(VALUE_TIME) AS EPICMAXTIME
result = 2019-10.03 ..
results me in two different answers ...
bot1q1-VisitorAuthor
No ideas?
I'm afraid you'll need to provide more context to understand what you're asking.
If i do an SELECT without "AS MyFanceValue" I receive  a different result then when i use "AS" in the select statement
Support
Hi @bot1q.
Please let us know if you found a solution for your issue.  If one of the previous posts helped to solve it, please mark the appropriate one as the Accepted Solution.  Otherwise, please post the solution you found and mark that as the Accepted Solution for the benefit of others with the same issue.
--Sharon
