Gauge Widget to show state definition with range value
I would like to display alarm and warning limits on both ends.
Meaning i should display
Alarm >80 and also < 10
Warning >60 and also <30
And value between 30 and 60 is normal
How should i set my state definition to achieve the same and if cannot achieve through gauge widget then what is the ideal work around to achieve the same.
Attached image for reference.
PaiChungAnswer
22-Sapphire I
You basically have 5 states
<10 - red
<30 - yellow
<60 - green
<80 - yellow
Default - red
PaiChung22-Sapphire IAnswer
22-Sapphire I
<10 - red
<30 - yellow
<60 - green
<80 - yellow
Default - red
sbt15-MoonstoneAuthor
Hello PaiChung,
My mistake!! but your solution is perfect, i tried the other way round.
Thank you for the response and guiding me through the approach.
