Get all enabled schedulers
Is there a way I can get a infotable of the enabled schedulers using GetEntities? What filters do I have to apply for that?
nmillesonAnswer
Use this code:
// result: INFOTABLE dataShape: "RootEntityList"
var t = ThingTemplates["Scheduler"].GetImplementingThingsWithData();
var query = {
 filters: {
 type: "EQ",
 fieldName: "Enabled",
 value: true
var params = {
	t: t /* INFOTABLE */,
	query: query /* QUERY */
var result = Resources["InfoTableFunctions"].Query(params);
nmilleson17-PeridotAnswer
Use this code:
var query = {
 filters: {
 type: "EQ",
 value: true
var params = {
Thank you! It's perfect
