Nov 13, 2019 4:17 AM UTC
get current Datatable row count
when I write services behind current datatable, I need to get number of rows of this datatable.
this is my code I used:
var result = me.getRowCount();
the output should be integer.
but after I run this code, here is output error says: cannnot find functon getRowCount in object com.thingworx.datatables.
how to fix this problem?
zyuan1Answer
Nov 13, 2019 7:36 AM UTC
Use this service instead:  GetDataTableEntryCount
Nov 13, 2019 7:35 AM UTC
The getRowCount() service is only used in infotable, so it returns the size of a infotable chunk, not the Datatable entity.
zyuan15-Regular MemberAnswer
xiaoqw1-VisitorAuthor
Nov 13, 2019 10:37 AM UTC
ok. thank you. it helps
