Get last x entries from DataTable
Dear community,
I would like to retrieve the last x (e. g. 10) records (by id) from a DataTable. This post nearly covers my problem but Streams do not suite my data and the second solution does not work because I have an additional filter. Here is what I thought should work:
var query = {
 "sorts": [
 "fieldName": "MessageId",
 "isAscending": false
 "filters": {
 "type": "EQ",
 "fieldName": "Direction",
 "value": 2
var entries = Things["MESMessageLogDT"].QueryDataTableEntries({
	maxItems: 10,
	query: query
MESMessageLogDT is the DataTable entity and I would like to get the last 10 records matching my filter criteria (Direction = 2), this is why I cannot simply take length - x.
However, the actual result is: The first 10 records but in descending order. So apparently the sequence of data processing is
  1. filter
  2. maxitems
  3. sort
while I need (and expected)
  1. filter
  2. sort
  3. maxitems
A workaround is this but the performance is poor and gets worse with every entry:
	maxItems: 9999999,
	query: query
entries = Resources["InfoTableFunctions"].TopN({maxItems:10, t:entries});
Is there any better approach?
Benny
22-Sapphire I
Stream entries come with oldest first y/n by default. DataTables unfortunately do not.
This is a design weakness in datatables for which at this time there is no way around.
at least I don't think there is a way around it.
