Get mashup dimensions for navigation popup size
we are using navigation with linked target mashup, which is get by a service. Based on other conditions, different target mashup is used for the navigation. Each of these mashups has different fixed size. Is there a was how to get mashup height and width so it can be linked to the navigation (popupHeight, poputWidth). Ideall would be to create a service that would have a mashup name on input and infotable with height and witdh on output. But I am struggling with reading mashup width and height.
Thank you.
Best option is to maintain a infotable with mashupname, height and width. WHen you know where to navigate( by mashupname) filter this infotable get important info out of it. Set the output in navigatation widget as shown in attached file.
Regards
Shyam
Regards
Shyam
Hello Shyam,
this option also get to me. But as it requires to manually create and maintain the infotable I was just wondering if it is possible to do it automatically. Isn't it really possible to somehow get mashup width and height if I know its name?
Thank you
As far as I know there is no way to know it. Just try to keep the default height and width as 0 for now. See if it auto adjust or not.
Regards
Shyam
