Get monitoring and log data via rest API
Is there any REST API or java sdk provided by ThingWorx  to get monitoring and logging data ?
PaiChungAnswer
22-Sapphire I
Hopefully this helps
https://www.ptc.com/en/support/article/CS329281?&language=en&posno=2&q=thingworx%20rest%20api%20post&source=search
The ServiceDefinitions should show you the parameters available, those you would construct and submit as a JSON in the body.
22-Sapphire I
You can just call the available services associated with the logs.
ok let me try and get back to you.  Thanks!
