Get Number of times update done for a single row in Datatable (Thingworx 9.1)
Hi ,
I am having one use case in that i need to check how many times a end user can change/update the particular field value. for Example
ID(Primary key) UserID
1 101
2 102
above table there will be restriction to update userID (Max 2 times can change/update a userID for ID 1) same will be for ID 2. how we can achieve this in TWX 9.1.
CharlesJiAnswer
Support
Hi @VaibhavShinde,
I guess you can create customized services for such field updates.
In those customized services, you may achieve the following logic:
if changed_time_of_xxx is over 2
  then return false
  else
    update the field
    changed_time_of_xxx increases 1
    return true
You may want to create another table where stores how many times a field has been changed (i.e., changed_time_of_xxx).
CharlesJiCommunity ManagerAnswer
Support
Hi @VaibhavShinde,
  then return false
  else
    update the field
    return true
