Get started guide Simulate a Data Source Things_House_data_simulator.xml is html
The download for simulated data appears to be a html file rather than an xml file with valid data. When trying to import
https://developer.thingworx.com/-/media/developerportal/Foundation%20Quickstart/Things_House_data_simulator.xml
When trying to import the file it returns Import failed with the following application log error
"Invalid request: org.xml.sax.SAXParseException; lineNumber: 2; columnNumber: 10; DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true."
Hello @SF_9687766 ,
Can you try unzipping the attached file and uploading it.
Hello @SF_9687766,
Have you tried using the left click to download the Things_House_data_simulator.xml or Save Link as to get the xml file.
Hello @SF_9687766 ,
Thank you for the link to download the simulation code. That is working fine now.
