Get the current session id from the opened mashup
Hi all,
I'm currently trying to trace down the usage from some mashups. The idea is to create a service that will be triggered by auto refresh every 60 secs containing (user, datetime, mashupname, current session id). Does anyone know how to obtain the current session id from the opened mashup (see the link below). Is there any session parameter that contains this?
e.g. https://thingworx-server/Thingworx/Runtime/index.html?mashup=Templatename&forceClose=true&__enableBMF=true&__fromNextGen=8587fe65-9d60-4cb0-bbcb-7d41a78d2169&features=#master=Mastertemplate&mashup=&forceClose=true&features=
jenscAnswer
You could use the "TW.location.href" function that is available in the Thingworx runtime (expression or validator).
This function gives you the entire URL, so you would have to write some code to get just the token.
The following gives some information around the runtime functions in Thingworx: PTC Help Center
Hope it helps.
Jens
jensc17-PeridotAnswer
Hope it helps.
Jens
I tried to call the function via expression function but I don't get any value. What I did is I created a expression function and write the following:
output = TW.location.href; //Output as a String
I then bind it with a label
Do you know what is the cause of this error or is there another way to get the complete url?
Did you trigger the service in any way?
As an example, you can use the mashups "Loaded" event to trigger the service.
The "Auto Evaluate" doesn't work unless you have an input that changes.
Jens
