Dec 19, 2019 10:31 AM UTC
Get the mashup button-ID from inside the called service
Is it possible to get the button-ID (and related properties) who started a service from a mashup ?
what I would make easier is this:
I have a service who makes a data-preview, or a data-import . This service is called from a mashup button.
A boolean variable can be set as service parameter to switch between the two functions.
I would have instead 2 buttons on the mashup, one that makes preview, another that makes import.
Is it possible to get button ID from inside the service ? If so, I can switch from preview and import without need to deal with a BOOL to set/reset from the mashup
I know I could do by duplicating the service .. and use one button for each one ... but make mashup mode complex ..
Dec 20, 2019 3:50 PM UTC
One of the ways to achieve your scenario is by using toggle buttons instead of regular buttons on the Mashup. Please follow the below steps to achieve your use case.
  1. Place two toggle buttons on the Mashup ( one for Preview and the other for Import)
  2. Create an Expression function that accepts two Boolean inputs and returns a Text output. (Expressions can be added from the bottom right corner of the Mashup)
  3. Bind the state of the toggle switches to the input parameters of the expression. Evaluate the expression with state changed event of the toggle switches.
  4. Code the Expression as below:
if(Inp1){
 Output = "Preview";
else if(Inp2){
 Output = "Import";
else{
 Output = "No action";
Now bind the output of this expression to the service that does your implementation. Please make sure it accepts String as an input parameter and write the condition accordingly. Please let me know if you run into any issues with the implementation.
Dec 19, 2019 3:41 PM UTC
Hi.
Check out this thread. Does it help in any way?
if(Inp1){
 Output = "Preview";
else if(Inp2){
 Output = "Import";
else{
Support
Dec 30, 2019 4:55 PM UTC
Hi @iguerra.
If one of the previous responses answered your question, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
