Get Thing Template implemented Thingshapes service
is there a service that will return a list of thingshapes implemented by a thing template (or thing derived from the thing template). Thought there would be as they are displayed in the composer, but can't find it.
Also looking for a service similar to GetServiceDefinitions() that will return the 'Category' parameter. That way I can filter the results so that I don't get all the services inherited from the base templates.
Thanks in advance.
K
mnarangAnswer
// result: INFOTABLE dataShape: "EntityList"
var result = me.GetImplementedShapes();
GetImplementedShapes will give you the list of implemented shapes on entity .
There is one more for getting the implemented ThingTemplate
var result = me.GetThingTemplate();
Thanks ,
Mukul Narang
mnarang5-Regular MemberAnswer
Thanks ,
Mukul Narang
khayes11-VisitorAuthor
Hi Mukul,
thanks for that, it is what I was looking for.
K
For the GetServiceDefinitions question it doesn't returns the Category, but you can filter by Category listing only the ones of the given Category ( if you know it in advance ).
