GetCurrentUserLanguage() is returning empty string
Hello
I want to localize the return of a function depending of the current language of the session of the connected user.
Everything is ok with the labels inot mashups using the "localization tables" but when i want to know the current language in a javascript I cannot get it
I'm using this
var Language = Resources["CurrentSessionInfo"].GetCurrentUserLanguage();
but it is returning an empty string (the user has "fr" in the languages item
any ideas
(ThingWorx 7.3.2-b42)
20-Turquoise
I will try to reproduce this during the U.S office hours tomorrow and will let you know whether it's a bug or a configuration issue.
pjoly1-VisitorAuthor
Hello
any news ?
20-Turquoise
Have you assigned result = Language; to display the result? also assign type String to the output.
Please get current user language setting as below.
    var result1 = Users[Username].GetUserPreferenceInfo();
    result=result1.getRow(2).value;
Below snippets DOES NOT return current setting, but return last setting when saving user settings directly from Composer. Report to R&D by Jira PSPT-5621
  • Resources["CurrentSessionInfo"].GetCurrentUserLanguage();
  • Users[username].language
