Jul 28, 2020 3:11 PM UTC
GetImplementingThingsWithData() performance issue for Large data set
Hi Folks,
@PaiChung @CarlesColl @Constantine
I have 500 Things to fetch properties from.And I have already tried fetching the Things first and then query for required properties only. But it still takes lot of time to execute.
Is there any other way to fetch larger set of data from Things in a least possible time.
Note: Already tried below workaround but no luck.
         var ThingsList = ThingTemplates["Template"].GetImplementingThings();
              var params = {
                     types: "STRING" ,
                     t: thingsList ,
                     columns: "MachineNumber",
                     expressions: "Things[name].MachineNumber"
18-Opal
Jul 29, 2020 7:56 AM UTC
Hello @TanmeyTWX,
Since 8.4.x the state-of-the-art in fast querying is QueryImplementingThingsWithNamedData, which allows you to limit the number of returned and checked properties. Take a look at this post for a working example: https://community.ptc.com/t5/ThingWorx-Developers/How-to-use-QueryImplementingThingsWithNamedData/m-p/627679
As of today, this is the fastest out-of-the-box way I'm aware of to query things, unless you are prepared to implement some Java extensions, custom caches, etc.
Constantine
Jul 29, 2020 7:40 AM UTC
Did you test this as well ?
QueryImplementingThingsWithNamedData * service that returns only the requested properties of all the implementing Things. This service is similar to QueryImplementingThingsWithData, but takes two additional parameters:
  • basicPropertyNames: Basic property name are the generic fields for all properties: name, description, tags, isSystemObject, homeMashup, avatar, projectName
  • propertyNames: any custom properties
The returned JSON consists of the implementing Things with only the desired properties as opposed to all properties
Mukul Narang
18-Opal
Hello @TanmeyTWX,
Constantine
Support
Aug 11, 2020 6:23 PM UTC
Hi @TanmeyTWX.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
Regards..
--Sharon
