Getting "502 Bad Gateway nginx" error while accessing https://servername/Thingworx/WS
Hi Team,
Please help on this issue.
Thanks in advance.
@RK_10356304 ,
Can you give us a little context on how and where you're trying to access this?  Is it for a TWx SDK? EMS? Other?
Nick
@nmilleson
The data is flowing from AWS kinesis stream to ThingWorx 9.3.3 via WebSocket Protocol.
@RK_10356304 ,
I'm not very familiar with Kinesis streams.  Are you subscribing to that stream somewhere and then sending to ThingWorx?  Typically when I have to connect to the ThingWorx websocket, the address is formatted as wss://servername/Thingworx/WS
-Nick
This issue might occur due to Thingowrx SSL .jks file is misplaced. Please restore the .jks file on original location or configure the .jks file path in server configuration side.
Thanks!
