Sep 17, 2014 9:56 PM UTC
Getting logged property values from value stream
I have a Thing with some logged properties. Properties are defined in the ThingTemplate as logged, not persistent, not read-only. I also tried direct logged properties with the Thing not from the ThingTemplate.
I have a ValueStream created and have it attached to the Thing. Property values change regularly on a Timer event (and manually).
How can I access the logged values for the logged properties either from the value stream or the thing itself? I don't see any ValueStream services for accessing the stream values. The documentation does not speak to how to get value stream data. What do I miss?
Calling service GetLoggedProperties on the Thing returns the logged properties, so this is OK.
Calling service GetPropertyLogging on the direct properties returns true, on a inherited properties from the template returns an error.
Thingworx 5.0.2.33
Much appreciated!
Sep 18, 2014 2:07 PM UTC
Hi Dwight,
I'm working on getting some documentation together for the
Services
of a
Value Stream
. For the time being, I can tell you the
Services
 for retrieving logged property values are on the
Thing
 with the properties being logged. There are a number of
Services
 for querying data for each basetype including
QueryBooleanPropertyHistory()
QueryNumberPropertyHistory()
 and
QueryInfoTablePropertyHistory()
to name a few.
I'll have to look into the error you're getting when calling
GetPropertyLogging()
 on
Properties
 inherited from a
ThingTemplate
. What is the error message?
Adam
dwightwhe1-VisitorAuthor
Sep 18, 2014 4:22 PM UTC
Adam: The comment below should have been a reply to your post. Thanks
Sep 18, 2014 4:16 PM UTC
Hi Adam,
thanks a lot. The QueryTypePropertyHistory Services on the Thing with the logged property work for me.
Regarding the observed error (is not a blocker for us): When I call Thing.GetPropertyLogging with a property inherited from the ThingTemplate, I get:
Property does not exist
When I make this call with a property that I define directly with the Thing, I get a normal result. Independent of that, I can query the property history for all logged properties. Thing.GetLoggedProperties also returns all inherited and direct properties just fine.
Thanks!
Sep 18, 2014 7:52 PM UTC
Sure thing. I was able to reproduce this issue and I've logged it in our case tracker.
Thanks for bringing this to our attention,
Adam
