getting transportException redirection blocked error while using the push function of GitBackupExten
I am trying to push my entities to gitlab repository using the push function available in gitbackup extension 4.1.0 in thingworx 8.5.8.
The exact error message is org.eclipse.jgit.api.errors.TransportException: <repository> redirection blocked
Support
Hi @VK_9983402.
This extension isn't supported by PTC but you may be able to submit your problem as an issue on github.  Just remember to provide the version of ThingWorx you are running.
--Sharon
