Jul 15, 2021 6:22 AM UTC
Ghost Subscription - Deleted subscription showing error
Hi All,
A subscription was deleted but even after the deletion whenever the event is triggered an error pops in the log saying the subscription (deleted one) is not found.
Error Message :
'Event handler <subscriptionName> not found. Cannot execute Subscription'
Thanks in Advance
Srijith
zyuan1Answer
Jul 15, 2021 6:59 AM UTC
You can rename the triggering event of the subscription, such as renameing the property if it triggers the subscription by value change event, this is a workaournd solution.
For Root cause, you can check in the DB for the Thing structure, if the subscription still exist/ export the thing to another TWX server, to check if the problem reproduce.
zyuan15-Regular MemberAnswer
Jul 15, 2021 10:12 AM UTC
Thank You @zyuan1 for the response
Here we are not able to rename the event.
How can I find within the DB if the subscription still exists?
Jul 19, 2021 2:11 AM UTC
It should be in the ThingModel table in your persistence provider, find the entity and check the details.
Support
Jul 21, 2021 5:55 PM UTC
Hi @SrijithKrish.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
