11-Garnet
Google Map
Hello,  is there any way to clean a selected location in the google map widget?
22-Sapphire I
You mean to have a 'deselect' since once you click on the map you have a selection?
I think you can bind an empty infotable to 'selected' and fire that in maybe on a button click?
Sorry it has been a very long time now that I've had to work with the map widget!
11-Garnet
I have a container with the expand/collapse option, when I select a marker on the map it should open the container and I want something so that I can deselect the marker and collapse the container at the same time
