Google map extension with Zipcode
Hello everyone,
Can you guys help me with a question on google map extension, does it support zip code?
I want to define region on the basis of zip code data and not on longitude, latitude as i don't have those data points.
If zip code does not support with google map extension then is there a way to get longitude, latitude using zip?
If you have any clue please share your thoughts or example.
Thanks.
Pravin P
Converting an address (or partial address like a zipcode) to latitude and longitude is called geocoding. Google as well as others can provide that service:
https://developers.google.com/maps/documentation/geocoding/overview
Support
Hi @PravinDriven.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
