Google Map tooltip close on click of google map
Hi Team,
I have to implement one functionality in which if I click on google map open tooltip should close. Is it possible in thingworx?
Support
Hi @IS_10098292.
Could you elaborate more on the issue?  Is it the Google map tooltip you're referring to?  Which version of ThingWorx are you running?  Which Google maps extension have you installed?
--Sharon
