Sep 16, 2017 3:27 AM UTC
Google Map Widget Tutorial?
hi all,
i am newbie to thingworx, i have several problem using google maps widget. is there any tutorial step by step using the google map widget.
i have problem to show marker on the location.
i have created infotable which has location and the location has default value(from datashape) but when i bind the info table to gmpas, i can choose location field as location, but in runtime, there is no marker, even though show marker set to true....
i dont know if i have created wrong infotable..
if there is link step by step how to use google maps, please let me know...
thanks
Sep 18, 2017 9:43 AM UTC
Hi, there's some Information available in the ThingWorx Help Center Topic Google Widgets. Plus there are some additional tutorial videos available on Google Widget here ThingWorx Video Tutorials -> see section ThingWorx Widgets
Hope this would help. Feel free to share your questions if you still run into issues.
20-Turquoise
Sep 18, 2017 12:51 PM UTC
Please refer to the helpcenter PTC
If you are still having problems with implementing after reviewing the documentation, please let me know and I will put up an example for you.
