Google Maps adding API key in version 3.0.3
Good day All,
I am having some difficulties getting the new version of the Google Maps Extension to work with a Google API key. I have followed the steps in the supporting documentation but I am clearly missing something.
I have created the API key, downloaded the extension from the marketplace and saved to a directory. When I execute the GetGoogleMapConnectionString I get this result:
And when I run the SetGoogleMapConnectionString I get the following error message:
"Unable to Invoke Service SetGoogleMapsConnectionString on PlatformSubsystem : Table [PlatformInformation] does not have a field named [googleMapsConnectionString]".
Any advice to what step I am missing?
Kind regards,
Johan Bester
Instead of executing the services you mentioned, I find it easier to modify the parameters in the Subsystem section of ThingWorx. There are directions that cover this method here:
https://developer.thingworx.com/en/resources/guides/google-map-widget-how/configure-google-maps-widget-extension
jbester14-AlexandriteAuthor
Hi @Rick-Stanley ,
Thank you for your reply. It seems like the version of Thingworx I am running (8.3.4) does not have the property "Required string to connect with Google for Google widgets" in the PlatformSubsystem. I am assuming then that Google Maps version 3.0.3 would not work, as documented, on Thingworx 8.3.3+?
Should I revert back to version 3.0.1?
Thanks for the assist.
