Got an error: Import Failed: Invalid Data Table Configuration in [..]: DataShape [..] was not found
I followed this post on ThingWorx Developer Portal to learn TWx and managed to import the template the post provides. But TWx gives this error:
Import Failed: Invalid Data Table Configuration in [MerchantDatabase] : DataShape [ MerchantDataShape ] was not found.
I then dived into the template file to take a look at it. The configuration of DataShape [MerchantDataShape] is actually there, not know why this error happens.
How to solve this problem? Thanks.
c_lowyAnswer
Hi @LL_9777686,
Is it the attached XML that you tried to import into ThingWorx ?
I just tried in ThingWorx 9.0.4 and the import was successful.
c_lowy16-PearlAnswer
Hi @LL_9777686,
Hi @c_lowy,
Yes, I tried to import in ThingWorx 9.1.0 but could not make it with the XML I mentioned in my post.
But the one you provide works. Thank you!
