Jan 22, 2024 5:36 AM UTC
Grid Advanced changed Behavier after upgrade
my company updated thingworx from 9.1.10 to 9.3.7 and now we got that wierd behavior on a Grid Advanced Widget.
What we want is only 1 row is selected and always at least 1 row is selected. So you cant unselect.
This worked as intended on 9.1.10 but after the upgrade we got actually a different behavior. The changedRow event always triggers, even i dont change it. I just click on the selected row and it will be unselected. I tried to play around with all properties and it still doesn't work.
Have anyone a working solution? Or will this be fixed in a upcoming version? Because we will not upgrade for the next 1 or 2 years.
Jan 22, 2024 6:03 AM UTC
Hi @AS_10340651
Use DefaultSelectedRows widget property to select rows by default in new Grid.
/VR
Jan 22, 2024 6:08 AM UTC
this will only make the selection at the start and we use it already:
I'm talkin about the "reselection" = deselected. This behavior is not wanted and was good on 9.1.10.
Jan 22, 2024 6:56 AM UTC
Hi @AS_10340651
I think it cannot be achieved in the new grid. You can make validation service which checks if row is selected or not
/VR
