Grid Column with image row style isn't applied
  • November 7, 2016
  • 4150 views
I have one issue with Thingworx: when some style is applied to whole Grid row (e.g. changed background color), it doesn't apply to a column with image. Setting the same style to that column itself didn't help also.
Screenshot is attached.
Thanks in advance
Oleh, does this only apply to a image basetypes or is it random? What version of ThingWorx are you using?
I have ThingWorx 7.1.4-b47 .
This only applies to IMAGELINK basetype.
I tried using an existing media entity and an image url - both seems to work. Can you attach the Style Definition you are using?
