Mar 12, 2025 2:35 PM UTC
Grid stops updating automatically when adding Image Field
I am facing a weird behavior with grid.
I am population grid with an infotable, I call it 'data_IT' . 'data_IT' is a property of a thing 'Thing_A'
In the mashup, I associate the 'data_IT'  to the grid using the service getproperties. and i check 'Automatically update values when...' so, when a row is updated,  it's replicated automatically in my mashup.
Everything works fine until I added a new field of type 'Image'. The automatic update stop working !
When i remove the image field, it's works fine again!!
Is there any solution for this bheavior ?
Thank you for you help
Mar 17, 2025 2:00 PM UTC
Thingworx version is 9.5.1 . I use the default widget grid.
I found  an other alternative. I use ImageLink instead of Image. The images are stored in my repository.
It solve the problem
Support
Mar 13, 2025 8:17 PM UTC
Hi @AliBenBelgacem
Which version of ThingWorx are you running?
Which grid widget are you using?  Have you tried a different one to see if the behavior is consistent?
--Sharon
AliBenBelgacem14-AlexandriteAuthorAnswer
Mar 17, 2025 3:03 PM UTC
Hi @AliBenBelgacem  Thanks for sharing the alternative solution, mark it as the solution for future reference.
