Grid widget rows are getting sorted automatically after service invoke completion in v9.3
Question :
Hello all , I have developed a Mashup in v9.1 which contains a grid widget. I have migrated the application to v9.3
The grid widget's rows are now getting sorted after service invoke completion which returns the data to the grid .
Thanks in advance for your support.
slangleyAnswer
Support
Hi @RK_10025077
Is it possible you changed the sort order under configure properties?  It may be caching the last change.
There are 2 sort options to check.  One is accessed by selecting the cog in the properties panel for the widget.  The other can be found in the upper-left corner of the widget --select Configure Grid Columns.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @RK_10025077
--Sharon
