Grid Widget without Enable Sorting setting (TWX 9.5)
With TWX 9.1.5, I've used Grid advanced widget to present infotables in mashups. If I wanted user to allow change sorting criteria, I ticked "enable sorting" in widget setting, and had buttons for operator to change sorting criteria (as far as I remember, it still needed to define service to make sorting).
With TWX 9.5, I use Grid - and have no setting called "Enable sorting". Was the name changed? Is this setting still available? If not - how can make interface for operator to allow him to set which column should be treated as sorting criteria, and also change it ascending/descending?
Rocko
RockoAnswer
It's configured per column in the "Configure Grid Columns" page (green cog icon). There you have "Sort Button" and Initial Sorting option.
The full process is described in the help.
https://support.ptc.com/help/thingworx/platform/r9/en/#page/ThingWorx/Help/Mashup_Builder/Widgets/Grid_SortingAndFilteringTheGridData.html#
Rocko
Rocko19-TanzaniteAnswer
