Gridadvanced in Twx 8.4.2-b2151
In thingworx 8.4.2-b2151, the selected date in datepicker widget is not showing in grid advanced widget when passing through services. In grid advanced the date is coming like this " ??? ". How to resolve it.
Support
Hi @AP_9587236.
ThingWorx 8.4 is no longer supported, but the Advanced Grid has seen several changes and it's now included in the platform instead of being installed as a separate extension.
Is there something preventing you from upgrading?
--Sharon
Even if we upgraded, does the twx version should be same with development team as well as with the client side? cos if the patch releases are different means i can see some differences in UI pages while comparing both the versions.
Support
Hi @AP_9587236.
You should be developing on the same version of ThingWorx you have deployed in Production.
--Sharon
