pshashipreetham
Sep 15, 2025 7:41 AM UTC
GUID Generation in Expression
Is it possible to generate a GUID in the Expression?, I remember seeing it long back in a Project, not sure what the correct syntax is to do it.
In my stiuation I am tring to avoid the service.
Thingworx: 9.4
18-Opal
Sep 15, 2025 9:12 AM UTC
Hey,
self.crypto.randomUUID()
...and ignore the warning about unsupported object.
Note that it only works when your ThingWorx is served over HTTPS or from localhost.
/ Constantine
Support
Sep 22, 2025 1:55 PM UTC
Hi @pshashipreetham
If you found the response from Constantine helpful, please mark it as the Accepted Solution for the benefit of other community members.
If you still have questions, please let us know.
--Sharon
Nov 8, 2025 12:02 AM UTC
Hi Shashi,
I just gave this a try using the line noted by @Constantine and this worked as expected in ThingWorx Platform 9.5.
Could you please give us some more information on what (if any) messages you are getting in the console when attempting to execute this Expression? On that note, could you also let me know how you are ensuring the Expression is being fired? In my test, I fired it by clicking a button and associated the output with a label:
output = self.crypto.randomUUID();
