8-Gravel
Hide or delete a specific item in a Menu
Hi all, i have a menu which has 10 items in it. For one site i need to have 10 menu item. For other site i only need 8 item in a menu. Suggest a code to hide or delete the menu items based on my condition. Thanks in advance
Create user groups with respect to plants.
Then add user groups to each menu item in Menu entity.
https://www.ptc.com/en/support/article/CS205546
Hello @KT_10107318,
Not sure what exact widget you are using, There may be a visible flag which is part of the menu definition. If you are providing an InfoTable to define the menu, the process of creating the infotable could accept a parameter to identify which version of the menu should be presented.
