host mapping using ip address
Is it possible to define a from ip range and to ip range and when the user logs in using organization if his ip fall's within from and to range he should land in a specific page. Eg: If the user ip is 192.168.0.100 - 192.168.0.109 he should land in station mashup. If user ip is between 192.168.0.110 - 192.168.0.120 he should land in Plant mashup.
Thanks in advance,
Shalini V.
zyuan1Answer
I think there's only Login control based on User roles right now, didn't see a IP filter in TWX platform.
zyuan15-Regular MemberAnswer
Support
Hi @svisveswaraiya_285988
If you are satisfied with the response from @zyuan1, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
