How can a user (authenticated one) access the Mashups?
I have created Mashups. How can a user (authenticated one) access these Mashups? Though here authentication is required how to do that(where to place Login Form and how to link it with Mashups)? How to navigate from one mashup to another? As I am new to ThingWorx I am looking for a right approach to do so. I am using ThingWorx 8.2 Composer. Please Help me.
Hello!
Please have a look at the following information and see if it helps:
https://www.ptc.com/en/support/article?n=CS181528
As you mention you are new to ThingWorx, I would like to point the following sources of information in case you are not aware of them:
- ThingWorx 8.2 Help Center
https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/
- Our KCS (Search our Knowledge Base)
www.ptc.com --> Go to "eSupport" --> Search the keywords using the field "Search the Knowledge Base"
For example, in this case, if you search for "ThingWorx Mashup deliver", you will find the article I mentioned above.
I hope this helps!
Best Regards,
Vanessa
