How can I add an invisible widget to a responsive mashup without it taking any space?
Hi all,
I wanted to add an AutoRefresh which is intended to be invisible to a responsive mashup. But since it is invisible i don't want to give it any space. The only way currently I see is to create another column/row (which will take at least 5% total space) just for this AutoRefresh. That space is lost...
Add a layout with header, and add this widget to the Header, then make the header:
Expanded=false
Overlay=true
Visible=false
You can set it visible=false, that's all
ybulankou1-VisitorAuthor
Thanks Carles, but the container that invisible widget is in is still going to take up space, even if we make refresh, the panel it is in, and column all invisible
Expanded=false
Overlay=true
Visible=false
