How can i delete a user assigned to various groups when he logged in and add him to respective group assigned from an external system dynamically?
  • June 2, 2017
  • 4 replies
  • 2980 views
I need help on deleting all the user assigned group programmatically and assign him to new group set on logging In.
Best answer by ankigupta
Hi Aakash D​,
Sushant Pandey already answered your query.
Let me give you an example; to add a User to Developer Group we can use following code:
var params = {
    member: "UserNameHere" /* STRING */,
    type: "User" /* STRING */
// no return
Groups["Developers"].AddMember(params);
Hi Aakash D​,
Could you please share your usecase in more detail. Are you using any ActiveDirectory for Authentication or are you using any custom Authenticator?
aakash.d21-VisitorAuthor
Hi Ankit Gupta​,
My process is actually after authentication, I will get the logged in user but I couldn't add the user to the respective user group dynamically.Is there a way through services in Thing
ankigupta5-Regular MemberAnswer
Hi Aakash D​,
var params = {
// no return
Aakash have you already checked the default services available under Organization, Groups and even for individual users. Like for a particular Group you have services like AddMember(), AssignMembers(), DeleteMembers() and you'll see similar ones for Organization as well.
