how can i generate database report in thingworx?
Hi ,
I am looking to generate database report(multiple database). can you explain here in few lines?
slangleyAnswer
Support
Hi @VaibhavShinde.
Please refer to this page from our ThingWorx Help Center and follow the examples provided.
--Sharon
20-Turquoise
Could you please elaborate on the use case here and your requirements?
I want to generate report in Grid format by retrieving data from database table , and i need to filter by using one of the column name with export button which will export data to excel.
How we can create it?
20-Turquoise
Is your database already connected to ThingWorx? You can connect any relational database via jdbc driver.
You would then write a sql command/query in a service to retrieve data. In the mashup, you can then use the advanced grid, a filter widget, and your query service bound to the filter and the grid to filter and sort data.
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FMashup_Builder%2FWidgets%2FAdvancedGrids.html
