How can I get current Mashup url
I want to capture current Mashup but It can not work.
Is there a URL that current Mashup in Thingworx?
Thank you.
kiyong.
supandeyAnswer
Hi Kiyong, i am not sure if get it right, are you looking to access your mashup via its URL? You can usually view all the mashups if you'd use something like this http://<ThingWorxServer>/Thingworx/Mashups
This will list you all the mashups and if you'd click on one of them you will have the direct URL to that mashup in your browser.
Please do correct me if i got your use case wrong.
Cheers.
supandey5-Regular MemberAnswer
Cheers.
kpark11-VisitorAuthor
Thanks for your reply.
But, I am looking to access my current mashup like this <http://ServerName/Thingworx/Runtime/index.html#mashup=MashupName&__fromBuilder=BuilderNumber​>​.
I want to know it is possible. Thank you.
Hi Kiyong, yes you can access it something like this http://<serverName>:8080/Thingworx/Runtime/index.html#mashup=DataTableMashup
Note here the DataTableMashup is the name of my Mashup. When accessing your mashups like that you will be prompted for the Authentication if you do not wish to authenticate via the Username/Password you can include the Application Key tied to that user directly in your URL
