How can I Import Sample Application to the Composer? Where is the Import/Export?
  1. Start on the Home tab of Composer.
  • In the top-right of Composer, click Import/Export.
  • Click IMPORT -> From File.
  • In the Import From File pop-up, keep the defaults and click Choose File.
  • Navigate to the Hello_World_Entities.twx file you previously downloaded.
  • Select the Entities file, then click Open.
  In the bottom-right of the Import From File pop-up, click the blue Import button.
    Now I understand.
    Import/Export bottom in the trial version not in academic version.
    nmohamed-21-VisitorAuthorAnswer
    Now I understand.
